  2. Allegro X Capture CIS
  3. Student license
  • State Suggested Answer
  • Answers 1
  • Subscribers 51
  • Views 4715
Student license
Fase5353453
Fase5353453 over 2 years ago
I used a student license for my old pc which is now broken.
Now I have a new PC and wanted to install PSpice there. Can I switch my license or update it?
  • TechiEE12
    TechiEE12 over 2 years ago +1 suggested
    Yes you can do a fresh installation in the new PC. I assume you still have a valid license which is not expired. Now there are two license scenarios: 1) If you were hosting the license file in your local…
  • TechiEE12
    0 TechiEE12 over 2 years ago
    1) If you were hosting the license file in your local machine, then you will need a new license file generated with MAC ID corresponding to your new machine.
    2) If you were pointing a remote license server to checkout the license then you need to add a environment variable CDS_LIC_FILE= %your remote server name%.
    Hope this helps.
