  2. Allegro X Capture CIS
  3. OrCAD 22.1 Ghostscript Not Able to Create PDF For Entire...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 7161
OrCAD 22.1 Ghostscript Not Able to Create PDF For Entire Schematic Using Hierarchical Design
CHBIO
CHBIO over 2 years ago
I'm using Ghostscript 10.03 and am unable to export my entire hierarchical design to PDF. I am selecting the .dsn file and going to File >Export > PDF and here is the window:
I am printing to my local Documents folder. Here is how my hierarchical design looks without expanding each schematic section:
The PDF export only generates the pages in the first schematic titled "01...". In the Session Log, I get the following information:
(::capPdfUtil::printPdf) Output Directory : c:\users\user_name\documents\test Output File : test.pdf
(::capPdfUtil::printPdf) Annotating page objects for 01 XX: PAGE1
(::capPdfUtil::printPdf) Generating PDF file from postscript ....
(::capPdfUtil::printPdf) Successful: GPL Ghostscript 10.03.0: Page object was reserved for an Annotation destination, but no such page was drawn, annotation in output will be invalid.
Does anyone know a fix?
  • Akshay khosla
    Akshay khosla over 2 years ago in reply to Akshay khosla +1 suggested
    Hi Sirena, Good to see that making the correct root schematic helped in creating the complete PDF of the hierarchical design.
  • Akshay khosla
    0 Akshay khosla over 2 years ago
    We will contact you through separate channel of communication in order to gather some more data and to check this at your end.
  • Akshay khosla
    0 Akshay khosla over 2 years ago in reply to Akshay khosla
    Hi Sirena,
  • ZenTechHelper
    0 ZenTechHelper over 2 years ago
    i will check this
