  2. Allegro X Capture CIS
  3. Problems when importing properties
  • State Verified Answer
  • Answers 1
  • Subscribers 51
  • Views 4915
JavierZgzSpain
JavierZgzSpain over 2 years ago
I was getting an error when importing properties in OrCAD Capture CIS v22.1 from a modified EXP file, previously exported. As I didn't know the reason, I eventually attempted to export the properties and then import them from the newly created file without making any changes. However, I still encountered the same error. Here is the error message:
ERROR(ORCAP-1704): (Line 163) Line has more fields than the previous HEADER line
I examined the component on that line, but I couldn't find anything wrong. What could be causing this error?
Javier
  • oldmouldy
    oldmouldy over 2 years ago +1 suggested
    An EXP file is tab delimited text, there are probably one, or more, tab characters embedded in the property values.
  • JavierZgzSpain
    JavierZgzSpain over 2 years ago in reply to oldmouldy +1 verified
    Thank you for the reply, oldmouldy I finally realized what the problem was: there were quotation marks in the description property. I deleted them and exported/imported correctly. .
  • oldmouldy
    0 oldmouldy over 2 years ago
  • JavierZgzSpain
    +1 JavierZgzSpain over 2 years ago in reply to oldmouldy
    Thank you for the reply, oldmouldy I finally realized what the problem was: there were quotation marks in the description property. I deleted them and exported/imported correctly..
