  2. Allegro X Capture CIS
  3. Design Sync Setup default values
  • State Verified Answer
  • Subscribers 50
  • Views 5056
Jim OMahony
Jim OMahony over 2 years ago
In the Orcad Capture 22.1 PCB > Design Sync Setup the default value of the field Create User Defined Properties = No.
Is it possible to change the default value to Yes ?
  • Akshay khosla
    Akshay khosla over 2 years ago in reply to Jim OMahony +2 verified
    Since this is a project level setting hence it saves this entry in the .opj file only as shown below: There is no option to control it using capture.ini currently.
  • Akshay khosla
    Akshay khosla over 2 years ago in reply to Jim OMahony +1 verified
    Hi Jim, We checked with the Tcl team and currently it can't be controlled by the Tcl as this is a project level setting.
  • Akshay khosla
    0 Akshay khosla over 2 years ago
    Hi Jim,
    From the drop-down menu as shown below, we can change the default value to “Yes”.
  • Jim OMahony
    0 Jim OMahony over 2 years ago in reply to Akshay khosla
    Hi Akshay, I am looking for a setting in capture.ini or other method to have the value always set to "Yes" unless the user selects the opposite. We have properties to transfer but users either don't know or forget to change this setting and then wonder why properties are not appearing in Layout.
  • Akshay khosla
    +1 Akshay khosla over 2 years ago in reply to Jim OMahony
    • Vote Up +2 Vote Down
  • Jim OMahony
    Could it be controlled by tcl on opening a project or design ?
  • Akshay khosla
    Hi Jim,
