  2. Allegro X Capture CIS
  3. CAPTURE PDF NET NAMES are not aligned how can i align it...
  • State Suggested Answer
  • Answers 2
  • Subscribers 52
  • Views 6552
CAPTURE PDF NET NAMES are not aligned how can i align it?
ssss12312
ssss12312 over 2 years ago
When outputting schematic to PDF, an error occurs where the net name grid does not fit as shown in the picture.
How do I solve this?
  • AG202604136617
    0 AG202604136617 7 months ago
    I also ran into this issue. This is the solution I got from Cadence Support:
    "The net names containing underscores (_) are intentionally elevated so that the underscores remain clearly visible in the exported PDF.
    To adjust this behavior, please run the following command in the Capture Command Window:
    SetOptionString PRINT_OFFSET_ALIAS_WITH_UNDERSCORE 0
    After running the command, close Capture and relaunch it. Then proceed with exporting the PDF. You should now see that the net names with underscores appear closer to the wire."
