  2. Allegro X Capture CIS
  3. CAPTURE PDF NET NAMES are not aligned how can i align it...
  • State Suggested Answer
  • Answers 2
  • Subscribers 52
  • Views 6551
CAPTURE PDF NET NAMES are not aligned how can i align it?
ssss12312
ssss12312 over 2 years ago
When outputting schematic to PDF, an error occurs where the net name grid does not fit as shown in the picture.
How do I solve this?
  • Akshay khosla
    0 Akshay khosla over 2 years ago
    Which OrCAD tool version (22.1 or 23.1) and the ghostscript driver version (like gs10.03)  you are using?
  • ssss12312
    0 ssss12312 over 2 years ago in reply to Akshay khosla
    Orcad version is 17.4 and ghostscript driver version is 10.03
    i dont know why this error Occured
  • Akshay khosla
    0 Akshay khosla over 2 years ago in reply to ssss12312
    Please confirm if this is a design specific issue or this is reproducible with all the designs.
  • Neil1234
    0 Neil1234 over 2 years ago
    I also have this issue, according to this post from 4 years ago it is due to the way underscores are handled by postscript.
    https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-design/46702/net-alias-name-not-aligned-schematic-pdf
    No solution was offered then. Would be nice if Capture could fudge the output to lower them by the amount postscript moves them up...
    Mine isn't quite as bad as yours though:
  • ssss12312
    0 ssss12312 over 2 years ago in reply to Neil1234
    I already solved that problem
    if user export schematic to PDF, you have to changing page size then can solved above problem
