  2. Allegro X Capture CIS
  3. OrCAD X Capture CIS : Keyboard shortcut to move a symbo...
  • Subscribers 50
  • Views 7245
OrCAD X Capture CIS : Keyboard shortcut to move a symbol
SamTronic
SamTronic over 2 years ago
I'm a new user on OrCAD x (I come from Altium) and I started to follow the "OrCAD X Capture with PCB Editor Tutorial" on the documentation of the software.
On the schematic, I'd like to find a way to move a symbol with a command (like a keybard shortcut and/or an icon on the interface) and keep the symbol hanging on the mouse cursor, like other ECAD software.
Is there a command to do this ?
  • Akshay khosla
    0 Akshay khosla over 2 years ago
    Hello Sam,
    The best way to move a part in OrCAD Capture is simply select and drag a component. You can move a part using the below command as well.
    1. Select the part which you want to move in schematic.
    2. Run the command in the command window Drag x y TRUE  (here x y are the coordinates where you want to move and place a component) as shown below
  • SamTronic
    0 SamTronic over 2 years ago in reply to Akshay khosla
    It's a shame not to have put an icon and a shortcut to move and stick the symbol on the mouse.
    You did it for OrCAD X Presto, we can even change the shortcuts in the Preferences menu.
    You have to know that when you spend hours on the design of the schematic, it can be stressful for the hand to stay long press with the left click to perform a simple action like moving a symbol.
    And I'm sure from a code point of view that is possible because when you place a new component, the symbol is stuck to the mouse.
    The only way I found to get around the problem is to do a "CTRL + X" and then "CTRL + V" but it's not very elegant to do like this.
  • SamTronic
    0 SamTronic over 2 years ago in reply to SamTronic
    Is there any chance of having this on a future release of OrCAD X Capture CIS ?
    If finished some tutorials and the Move icon on Presto is very convenient.
  • Akshay khosla
    0 Akshay khosla over 2 years ago in reply to SamTronic
    An enhancement CCR has been filed for this.
