  2. Allegro X Capture CIS
  3. Orcad X 23.1 CIS design sync setup window doesn't respo...
  • State Verified Answer
  • Subscribers 51
  • Views 3202
Orcad X 23.1 CIS design sync setup window doesn't respond
Stevenson
Stevenson over 2 years ago
In the "design sync setup" window, none of the buttons (OK, Cancel, Help) responds. And I can't see the file browse window if I click "..." button to browse the layout folder. I can only close it by clicking on the "x" on the top right. And it doesn't take effect. The same thing happens to PCB-> New Layout window.
  • Jeet
    Jeet over 2 years ago +1 verified
    Try using following steps: 1. Close Capture if already Running. 2. Open and Edit in notepad (or in text editor) <installation-dir>/tools/bin/orCEFSettings.ini 3. Add following line in this file : lang…
  • Jeet
    +1 Jeet over 2 years ago
    lang=en-US
    4. Save the file.
    5. Run Capture and check if issue still persists.
    Let me know how it goes for you after performing the steps, are you able to resolve your issue regarding New Layout window?
    Also, which operating system you are using at which OrCAD Capture is installed.
  • Stevenson
    0 Stevenson over 2 years ago in reply to Jeet
    It works! Thank you!
    The OS is windows 11 home edition 10.0.22631
    OrCAD X Professional Plus 23.1 S003 (4178961) [3/6/2024]
  • Jeet
    0 Jeet over 2 years ago in reply to Stevenson
    Great that it worked for you and encourage you to visit Forum whenever you face any issue.
    Let me know just one thing, in which language you are using your OS was it Chinese or Japanese?
  • Stevenson
    Chinese
