  2. Allegro X Capture CIS
  3. Run TCL script from Windows terminal to OrCAD Capture t...
  • State Verified Answer
  • Subscribers 51
  • Views 8786
Run TCL script from Windows terminal to OrCAD Capture terminal
AB_1717543042707
AB_1717543042707 over 2 years ago
Is there any way to execute a command from a windows terminal to send a tcl script to the Capture terminal? I am trying to automate the process of having to manually type in "source {path_to_tcl_script}" in the Capture command window and wanted to see if there is any way this can be done from a windows terminal.
Something that almost works is doing C:\Users\$user> "path_to_capture.exe" "path_to_tcl_script" but this doesnt work for me as it is really slow and breaks half the time.
Any advice on how to accomplish this would be greatly appreciated.
Thanks.
  • CadAP
    CadAP over 2 years ago +1 verified
    HI AB_1717543042707 , Please check the below article available on Cadence Online support. support.cadence.com/.../ArticleAttachmentPortal Also you can try below command, Open cmd and cd to…
  • CadAP
    +1 CadAP over 2 years ago
    HI AB_1717543042707,
    Open cmd and cd to C:/Cadence/SPB_22.1/tools/bin then try the below command.
    capture -product="OrCAD Capture" <path with tcl file name>
    Hope this help.
  • AB_1717543042707
    0 AB_1717543042707 over 2 years ago in reply to CadAP
    Thank you,
    I saw your other comment on using the orcad library and that worked well for me.
    What worked for me was running this in a tcl shell:
    load [file normalize “C:/<Capture_inst-dir>/tools/bin/orDb_Dll_Tcl64.dll”] DboTclWriteBasic
    And then I could run, source [file normalize “<path_to_tcl>”] to run my tcl script
    Thanks again
  • cineboxandrew
    0 cineboxandrew over 1 year ago in reply to AB_1717543042707
    Attempting to do the same thing for me results in the interpreter crashing with exit code 0xC0000005. Ive tried it in both IronTCL 64-bit 8.6 and through the TCL in python tkinter with the same results. Any ideas?
