  2. Allegro X Capture CIS
  3. Need help extracting net alias names
  • Subscribers 50
  • Views 3970
AB_1717543042707
AB_1717543042707 over 2 years ago
I want to see if there is a way to extract the aliases of a net using TCL. I believe the command I am looking for is GetNetAliasArray() however, I can not figure out how to get the output to readable text. The command GetNetAliasArray() returns DboPtrArray and I can't find the TCL helper command to convert this data type into text, if that's even how you do it. If anyone knows how to do this or if there is a different approach to this I would appreciate it.
  • CadAP
    0 CadAP over 2 years ago
    Hi  AB_1717543042707,
    Please find the below two code for extracting the net alias name:
    To run the first code(below) , you need to select the couple of nets(see below screen shot) from the open page and source the below tcl code:
    set lSelectedWires [GetSelectedObjects]
    set lAliasName [DboTclHelper_sMakeCString]
    foreach lWire $lSelectedWires {
    set lAliasIter [$lWire NewAliasesIter $lStatus]
    #get the first alias of wire
    set lAlias [$lAliasIter NextAlias $lStatus]
    while { $lAlias!=$lNullObj} {
    #placeholder: do your processing on $lAlias
    puts $lAlias
    $lAlias GetName $lAliasName
    puts [DboTclHelper_sGetConstCharPtr $lAliasName]
    #get the next alias of wire
    delete_DboWireAliasesIter $lAliasIter
    For second code(below)  you need to select the design from the Project manager of Capture(see below screenshot) and source the below tcl code:
    set lNets [CapFindObjects $COrFindFilterDlg_NETS {*}]
    set lStatus [DboState]
    set netname [DboTclHelper_sMakeCString]
    set lNullObj NULL
    foreach lNet $lNets {
    set lWiresIter [$lNet NewWiresIter $lStatus]
    #get the first wire
    set lWire [$lWiresIter NextWire $lStatus]
    puts $lWire
    set lObjectType [$lWire GetObjectType]
    if {$lObjectType == $::DboBaseObject_WIRE_SCALAR} {
    # #get the first alias of wire
    puts $lAlias
    # $lWire GetNetName $netname
    # puts [DboTclHelper_sGetConstCharPtr $netname]
    #placeholder: do your processing on Wire scalar $lWire
    #get the next wire
    Hope this will help you to get your desired result.
  • AB_1717543042707
    0 AB_1717543042707 over 2 years ago in reply to CadAP
    No this wasn't quite what I was looking for. The real problem I was having was that I am trying to get every name of a wire on a page. I already have code to iterate over every schematic, every page, and every wire. However, when I use the GetNetName command for my wire, it only returns the top name for the wire. In my design, I have wires that have more than one name. I want to find a way to extract all of the names of each wire. Do you know how I can do this? I appreciate it.
