  2. Allegro X Capture CIS
  3. Extracting All Names from Wires with Multiple Names
  • State Verified Answer
  • Subscribers 51
  • Views 5968
AB_1717543042707
AB_1717543042707 over 2 years ago
The problem I am having is that I am trying to get the names of wires on a page. I already have code to iterate over every schematic, every page, and every wire. However, when I use the GetNetName command for my wire, it only returns the top name for the wire. In my design, I have wires that have more than one name. I want to find a way to extract all of the names of each wire. Does anyone know how I can do this?
I appreciate it.
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi AB_1717543042707, You can try the below code which will give you schematic net, Alias Name and Net Name of a wire. Need to select the design and source the below code. set lNets [CapFindObjects…
  • CadAP
    CadAP over 2 years ago in reply to AB_1717543042707 +1 verified
    Hi AB_1717543042707, Good to hear that it worked for you. Please find the below code which need to be sourced(capture command window) without selecting the design. set lSession $::DboSession_s_pDboSession…
  • tennywhy
    0 tennywhy over 2 years ago in reply to CadAP
    it always stucked at the error: can't read "COrFindFilterDlg_NETS": no such variable .how i can solve this error, teach me please. thanks
