  2. Allegro X Capture CIS
  3. Extracting All Names from Wires with Multiple Names
  • State Verified Answer
  • Subscribers 51
  • Views 5967
AB_1717543042707
AB_1717543042707 over 2 years ago
The problem I am having is that I am trying to get the names of wires on a page. I already have code to iterate over every schematic, every page, and every wire. However, when I use the GetNetName command for my wire, it only returns the top name for the wire. In my design, I have wires that have more than one name. I want to find a way to extract all of the names of each wire. Does anyone know how I can do this?
I appreciate it.
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi AB_1717543042707, You can try the below code which will give you schematic net, Alias Name and Net Name of a wire. Need to select the design and source the below code. set lNets [CapFindObjects…
  • CadAP
    CadAP over 2 years ago in reply to AB_1717543042707 +1 verified
    Hi AB_1717543042707, Good to hear that it worked for you. Please find the below code which need to be sourced(capture command window) without selecting the design. set lSession $::DboSession_s_pDboSession…
  • CadAP
    +1 CadAP over 2 years ago
    set lNets [CapFindObjects $COrFindFilterDlg_NETS {*}]
    set lStatus [DboState]
    # set lAliasName [DboTclHelper_sMakeCString]
    # set lNetName [DboTclHelper_sMakeCString]
    # set lSchiNetName [DboTclHelper_sMakeCString]
    set lNullObj NULL
    foreach lNet $lNets {
    set lWiresIter [$lNet NewWiresIter $lStatus]
    #get the first wire
    set lWire [$lWiresIter NextWire $lStatus]
    while {$lWire != $lNullObj} {
    puts $lWire
    $lWire GetNetName $lNetName
    $lNet GetName $lSchiNetName
    set lObjectType [$lWire GetObjectType]
    if {$lObjectType == $::DboBaseObject_WIRE_SCALAR} {
    set lAliasIter [$lWire NewAliasesIter $lStatus]
    # #get the first alias of wire
    set lAlias [$lAliasIter NextAlias $lStatus]
    while { $lAlias!=$lNullObj} {
    #placeholder: do your processing on $lAlias
    $lAlias GetName $lAliasName
    set AliasNetName [DboTclHelper_sGetConstCharPtr $lAliasName]
    set SchiNetName [DboTclHelper_sGetConstCharPtr $lSchiNetName]
    set NetName [DboTclHelper_sGetConstCharPtr $lNetName]
    #get the next alias of wire
    # puts $lAlias
    # $lWire GetNetName $netname
    # puts [DboTclHelper_sGetConstCharPtr $netname]
    #placeholder: do your processing on Wire scalar $lWire
    #get the next wire
    delete_DboWireAliasesIter $lAliasIter
    puts "AliasNetName: = $AliasNetName , SchiNetName := $SchiNetName , NetName: = $NetName"
    If this doesn't work for you then can you please share the screen shot of you schematic(a wire with multiple name) for what you are looking for.
  • AB_1717543042707
    0 AB_1717543042707 over 2 years ago in reply to CadAP
    This code almost works for me. I just need help figuring out how I can get the lNets variable but by iterating through the design rather than having to select the design manually and then sourcing the code. So to clarify, instead of using set lNets [CapFindObjects SCOrFindFilterDIg-NETS {*}], I would like to iterate over the entire design, that way I do not have manually select the design in capture.
    I really appreciate your help.
  • CadAP
    +1 CadAP over 2 years ago in reply to AB_1717543042707
    DboSession -this $lSession
    set lDesign [GetActivePMDesign]
    set lNullObj NULL
    if { $lDesign!= $lNullObj} {
    # puts $lDesign
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    # get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    puts $lView
    while { $lView != $lNullObj} {
    # dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    set schematicName [DboTclHelper_sMakeCString]
    $lSchematic GetName $schematicName
    puts [DboTclHelper_sGetConstCharPtr $schematicName]
    set lSchiName [DboTclHelper_sGetConstCharPtr $schematicName]
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    # get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    set lNullObj NULL
    while {$lPage!=$lNullObj} {
    # placeholder: do your processing on $lPage
    set pageName [DboTclHelper_sMakeCString]
    $lPage GetName $pageName
    puts [DboTclHelper_sGetConstCharPtr $pageName]
    set lPageName [DboTclHelper_sGetConstCharPtr $pageName]
    # get the next page
    set lWiresIter [$lPage NewWiresIter $lStatus]
    #get the first wire
    set lNullObj NULL
    set lNet [$lWire GetNet $lStatus]
    $lNet GetNetName $lSchiNetName
    # puts $lAlias
    #get the next wire
    delete_DboPageWiresIter $lWiresIter
    delete_DboSchematicPagesIter $lPagesIter
    delete_DboLibViewsIter $lSchematicIter
  • AB_1717543042707
    Sorry for the late response but, this worked for me well. Thank you, I appreciate it.
  • CadAP
    0 CadAP over 2 years ago in reply to AB_1717543042707
    @AB_1717543042707 thanks for your feedback.
