  2. Allegro X Capture CIS
  3. Editing the schematic symbol part properties using the TCL...
  • State Verified Answer
  • Replies 7
  • Subscribers 50
  • Views 17492
Editing the schematic symbol part properties using the TCL command in OrCAD Capture
RohitRohan
RohitRohan over 2 years ago
Hai Community,
I want to copy all the values of one property tab to another property tab using the TCL command in the Capture.
For example, in the below image, there is PCB Footprint value property defined for all the schematic symbols, also there is PCB_FP properties for which values are blank for all the schematic symbols.
Can i use the TCL command such that all the values of PCB Footprint property will be transfer or copied to PCB_FP property for all schematic symbols.
For reference, Once the TCL command executed / completed, below is how it should look like after execution  (Note: In the below image the values are edited using Microsoft paint and not using the OrCAD Capture, (Edited image))
Rohit Rohan
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi RohitRohan, Please use the below tcl code for updating the property name "PCB_FP" with the value taken from "PCB Footprint" property. set lSession $::DboSession_s_pDboSession DboSession -this…
  • CadAP
    CadAP over 2 years ago in reply to RohitRohan +1
    Hi Rohit, I am good, I believe you are also good. Try below tcl code, Property which are not locked by schematic are deleted. set lSession $::DboSession_s_pDboSession DboSession -this $lSession…
  • CadAP
    CadAP over 2 years ago in reply to RohitRohan +1 verified
    Hi Rohit Rohan, Please find the tcl for changing the selected Part pin name from VSS to Vss$Pin_Number. For example, If a part has the pin name VSS and the same pin has pin number 1, then the new…
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to CadAP
    Hai CadAP,
    Thank you so much for the previous TCL code and I really appreciate it. Slight smile
    Currently I have an very urgent requirement, I have a schematic symbol of 100 pins, the problem is all the 100 pins are having the same pin name which is "Vss", when I create netlist from the schematic it creates an error stating that pin names are duplicated, I have disabled the DRC check for duplicate pin names but still the same problem.
    Is it possible to create a TCL command such that I want to change the Pins names of the schematic symbol in sequence order, like the schematic symbol has 100 pins with all being Vss, I want to make them like Vss1 to Vss100 using the TCL command.
    Rohit Rohan
  • CadAP
    +1 CadAP over 2 years ago in reply to RohitRohan
    Hi Rohit Rohan,
    For example,
              If a part has the pin name VSS and the same pin has pin number 1, then the new pin name will be VSS1.
    set lStatus [DboState]
    set lInst [GetSelectedObjects]
    set lPlacedInst [DboPartInstToDboPlacedInst $lInst]
    #Get DboLibPart from the Placed Inst
    set lPart [$lPlacedInst GetPart $lStatus]
    set lIter [$lPart NewPinsIter $lStatus]
    set lNullObj NULL
    set lPinNameCS [DboTclHelper_sMakeCString]
    set lPinNumberCS [DboTclHelper_sMakeCString]
    #get the first pin of the part
    set lPin [$lIter NextPin $lStatus]
    while {$lPin !=$lNullObj } {
    $lPin GetPinName $lPinNameCS
    set lPinName "[DboTclHelper_sGetConstCharPtr $lPinNameCS]"
    # puts $lPinPos
    if {$lPinName == "VSS"} {
    set lPinPos [$lPin GetPinPosition $lStatus]
    set lNewPinPos [expr {$lPinPos + 1}]
    set lNewPinName "$lPinName$lNewPinPos"
    set lNewPinNameCS [DboTclHelper_sMakeCString "$lNewPinName"]
    set lStatus [$lPin SetPinName $lNewPinNameCS]
    if {[$lStatus OK] != 1} {
    puts "Error in changing the pin name of $lNewPinName"
    #get the next pin of the part
    $lStatus -delete
    delete_DboSymbolPinsIter $lIter
    Hope this will address your current concern and let you move forward in your design process.
