  2. Allegro X Capture CIS
  3. Editing the schematic symbol part properties using the TCL...
  • State Verified Answer
  • Replies 7
  • Subscribers 50
  • Views 17491
Editing the schematic symbol part properties using the TCL command in OrCAD Capture
RohitRohan
RohitRohan over 2 years ago
Hai Community,
I want to copy all the values of one property tab to another property tab using the TCL command in the Capture.
For example, in the below image, there is PCB Footprint value property defined for all the schematic symbols, also there is PCB_FP properties for which values are blank for all the schematic symbols.
Can i use the TCL command such that all the values of PCB Footprint property will be transfer or copied to PCB_FP property for all schematic symbols.
For reference, Once the TCL command executed / completed, below is how it should look like after execution  (Note: In the below image the values are edited using Microsoft paint and not using the OrCAD Capture, (Edited image))
Rohit Rohan
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi RohitRohan, Please use the below tcl code for updating the property name "PCB_FP" with the value taken from "PCB Footprint" property. set lSession $::DboSession_s_pDboSession DboSession -this…
  • CadAP
    CadAP over 2 years ago in reply to RohitRohan +1
    Hi Rohit, I am good, I believe you are also good. Try below tcl code, Property which are not locked by schematic are deleted. set lSession $::DboSession_s_pDboSession DboSession -this $lSession…
  • CadAP
    CadAP over 2 years ago in reply to RohitRohan +1 verified
    Hi Rohit Rohan, Please find the tcl for changing the selected Part pin name from VSS to Vss$Pin_Number. For example, If a part has the pin name VSS and the same pin has pin number 1, then the new…
  • CadAP
    +1 CadAP over 2 years ago
    Hi RohitRohan,
    set lNullObj NULL
    set lStatus [DboState]
    set lDesign [$lSession GetActiveDesign]
    set lSchi_Name [DboTclHelper_sMakeCString]
    set lPartCount 0
    set lPropName [DboTclHelper_sMakeCString "PCB Footprint"]
    set lPropName1 [DboTclHelper_sMakeCString "PCB_FP"]
    set lPropValue [DboTclHelper_sMakeCString]
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    #get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    # set lPage_Name [DboTclHelper_sMakeCString]
    while { $lView != $lNullObj} {
    #dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    $lSchematic GetName $lSchi_Name
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    #get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    # puts [DboTclHelper_sGetConstCharPtr $lSchi_Name]
    while {$lPage!=$lNullObj} {
    # puts [DboTclHelper_sGetConstCharPtr $lPage_Name]
    set lPartInstsIter [$lPage NewPartInstsIter $lStatus]
    #get the first part inst
    set lInst [$lPartInstsIter NextPartInst $lStatus]
    while {$lInst!=$lNullObj} {
    #dynamic cast from DboPartInst to DboPlacedInst
    set lPlacedInst [DboPartInstToDboPlacedInst $lInst]
    if {$lPlacedInst != $lNullObj} {
    set lObjType [$lPlacedInst GetObjectType]
    if {$lObjType == 13} {
    #placeholder: do your processing on $lPlacedInst
    set lStatus [$lPlacedInst GetEffectivePropStringValue $lPropName $lPropValue]
    if {[$lStatus OK] ==1} {
    $lPlacedInst SetEffectivePropStringValue $lPropName1 $lPropValue
    incr lPartCount
    $lStatus -delete
    # $lPlacedInst GetName $lPart_Name
    # puts $lObjType
    # puts $lObjType
    #get the next part inst
    #get the next page
    delete_DboSchematicPagesIter $lPagesIter
    #get the next schematic view
    delete_DboLibViewsIter $lSchematicIter
    puts "$lPartCount Parts PCB_FP poperty are updated"
    Please check and let me know you feedback.
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to CadAP
    Hai, i have checked the same TCL code in the OrCAD Capture and its working Blush
  • RohitRohan
    Hai CadAP,
    Hope you are doing well,
    Similarity, can we create a TCL code for removing all the properties of all the schematic symbol in the schematic design.
    Like there are few schematic symbol on the schematic page, I want to remove all the properties of each and every symbols using the TCL command.
    Rohit Rohan
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to RohitRohan
    Or at least to delete all the user defined properties for the schematic symbols in the schematic design.
  • CadAP
    0 CadAP over 2 years ago in reply to RohitRohan
    Hi Rohit,
    set lNullObj NULL
    set lPart_Name [DboTclHelper_sMakeCString]
    set lPart_Name1 [DboTclHelper_sMakeCString]
    set lPrpName [DboTclHelper_sMakeCString]
    set lPrpValue [DboTclHelper_sMakeCString]
    set lPrpType [DboTclHelper_sMakeDboValueType]
    set lEditable [DboTclHelper_sMakeInt]
    set propnamelist {}
    if {$lDesign != $lNullObj} {
    #get the first page
    #placeholder: do your processing on $lPage
    $lPage GetName $lPage_Name
    set lPropsIter [$lPlacedInst NewEffectivePropsIter $lStatus]
    set lStatus [$lPropsIter NextEffectiveProp $lPrpName $lPrpValue $lPrpType $lEditable]
    while {[$lStatus OK] == 1} {
    #placeholder: do your processing for $lPrpName $lPrpValue $lPrpType $lEditable
    set lPropName [DboTclHelper_sGetConstCharPtr $lPrpName]
    set lState [$lPlacedInst DeleteEffectiveProp $lPrpName]
    # puts [DboTclHelper_sGetConstCharPtr $lPrpName]
    #get the next effective property
    delete_DboEffectivePropsIter $lPropsIter
    #get the next page
    # return $partlist
    Please let me know your feedback.
