  2. Allegro X Capture CIS
  3. Is there a way to automatically remove postscript files...
  • State Verified Answer
  • Subscribers 50
  • Views 4385
Is there a way to automatically remove postscript files when PDF creation is complete?
Gabor Sz
Gabor Sz over 2 years ago
In OrCAD Capture CIS version 17.2, Using the Export PDF function to create a PDF leaves behind several postscript files with names like CapMark.ps
I noticed this recently after upgrading to a newer computer and don't remember this behavior in my previous environment.  The PDF files are correctly created.  Is there something in the settings (possibly converter arguments for Ghostscript?) that will remove these files when the PDF file creation is complete?
I'm using Ghostscript 64 bit / equivalent
Converter Path:
D:\Cadence\GSwin64\bin\gswin64c.exe
Converter Arguments:
-sDEVICE=pdfwrite -sOutputFile=$::capPdfUtil::mPdfFilePath -dBATCH -dNOPAUSE $::capPdfUtil::mPSFilePath
  • Gabor Sz
    Gabor Sz over 2 years ago +1 verified
    So in the end it turns out that the problem is using gswin64c.exe rather than gswin64.exe Both of these programs were installed when I downloaded Ghostscript. Using gswin64.exe, I no longer have postscript…
  • rg13
    0 rg13 over 2 years ago
    Postscript files are temporarily created during the process of exporting PDF for any design in Capture using ghostscript.
    Could you please try following suggestion:
    -  There is no space in design name and path to design.
    - There is no space in PDF file name and path to PDF file.
    See if it works for you.
  • Gabor Sz
    0 Gabor Sz over 2 years ago in reply to rg13
    I tried that, and there's no difference in behavior.  Just to make sure I created a new project in D:\Temp with name TempProj and standard page names, and it also has postscript files left over after creating a PDF.
  • Gabor Sz
    +1 Gabor Sz over 2 years ago
    Both of these programs were installed when I downloaded Ghostscript.  Using gswin64.exe, I no longer have postscript files left after the PDF file is created.  I see no differences in the PDF file created by the two Ghostscript executables.
