  2. Allegro X Capture CIS
  3. Schematic PDF exporter is only producing .ps files but not...
  • State Verified Answer
  • Subscribers 51
  • Views 6404
Schematic PDF exporter is only producing .ps files but not the .pdf
jshoemaker
jshoemaker over 2 years ago
Looking for some help with this. OrCAD exports the CapMark.ps file, the CapOutput.ps file, and the CapPropMark.ps file but not the .pdf. I have installed ghostscript x64 and tried pointing to both the gswin64.exe and gswin64c.exe. I have also tried the x32 version of ghostscript. I am using 17.4-2019 S039 and windows 11. Thanks.
  • TpermanLuma
    TpermanLuma over 2 years ago +2 verified
    Do you have any spaces in the output directory path? e.g in folder name I had issues with PDF generation which were resolved once I replaced spaces with underscores.
  • jshoemaker
    jshoemaker over 2 years ago in reply to TpermanLuma +1
    This fixed it. Having onedrive forces a space in the path so i can no longer export to my desktop. Thanks!
  • jc teyssier
    jc teyssier over 2 years ago in reply to jshoemaker +1
    Always avoid space and special characters in path and file names: using them lead to problems in so much cases. Use: a to z - underscore _ numbers and that all: never a problem Other…
  • TpermanLuma
    +1 TpermanLuma over 2 years ago
    • Vote Up +2 Vote Down
  • jshoemaker
    0 jshoemaker over 2 years ago in reply to TpermanLuma
  • jc teyssier
    0 jc teyssier over 2 years ago in reply to jshoemaker
    Use:
    a to z
    underscore _
    numbers
    Other tip:
    avoid too long path ans filename, windows have limitations
    Jean-Charles
