  2. Allegro X Capture CIS
  3. Older OrCAD schematic viewing. translation error STD.CFG...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 3077
Older OrCAD schematic viewing. translation error STD.CFG file
Seaward Lampray
Seaward Lampray over 2 years ago
Hello there,
we are trying to access older OrCAD schematic files with the latest viewer.
getting following error..
ERROR(ORCAP-39058): Parsing error found at line   5, column  14, '=' expected.
here is the first portion of our STD.cfg file from the older system its having a hard time with.
{ OrCAD/SDT IV Configuration File }
PDRV = 'C:\ORCADESP\DRV\'
PSCH = ''
PLIB = 'C:\Cadence\PCBViewers_2023\tools\capture\library\*.LIB
DD = 'VGA640.DRV'
PRD = 'HPLASER3.DRV'
PLD = 'HP2.DRV'
LIB = 'TOP.LIB'
LIB = 'TTL.LIB'
LIB = 'CMOS.LIB'
LIB = 'DEVICE.LIB'
LIB = 'ANALOG.LIB'
LIB = 'DALLAS.LIB'
LIB = 'IMETRIX.LIB'
LIB = 'EMILE.LIB'
LIB = 'DOUG.LIB'
DMF = ''
DIM = ''
LMF = ''
any help would be great
  • Akshay khosla
    Akshay khosla over 2 years ago +1 suggested
    Hi, In line 5, PLIB = 'C:\Cadence\PCBViewers_2023\tools\capture\library\*.LIB ' is missing at the end, try adding apostrophe ' in the ending as shown below: PLIB = 'C:\Cadence\PCBViewers_2023\tools…
  • Akshay khosla
    0 Akshay khosla over 2 years ago
    PLIB = 'C:\Cadence\PCBViewers_2023\tools\capture\library\*.LIB'
