  2. Allegro X Capture CIS
  3. Orcad Capture 23.1 won't back annotate from Orcad X / PCB...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 3939
Orcad Capture 23.1 won't back annotate from Orcad X / PCB Designer
passedpawn
passedpawn over 2 years ago
I've designed two boards now without too much trouble.  The forward annotation works great (ECO | Update PCB). However, the other direction (ECO | Update Schematic ) always fails.  I'm not sure why it's failing - my only clue is the "Checking physical rules" error.  What causes this?
Thanks so much in advance.  I re-arragned the refdes on one of them and now it remains out of sync until I resolve this.
  • Jeet
    Jeet over 2 years ago in reply to Jeet +1 suggested
    As per our discussion after making the schematic and layout in sync and renaming the refdes in OrCAD X Presto and saving .brd you were able to back annotate the changes in OrCAD X Capture without getting…
  • Jeet
    0 Jeet over 2 years ago
    It is Important to keep the schematic design and board file in sync before any change is done on the board file.
    To bring them in sync, update the board with the schematic with the following steps >
    1.Go to PCB > Update Schematic.
    2.Click on Sync to update the board with the schematic design.
    Update Schematic shows all the changes which are being done from the schematic to the board file.
    Which changes you are Back annotating in the schematic design.  Also, Is there any mechanical part which is placed in the schematic design?
  • passedpawn
    0 passedpawn over 2 years ago in reply to Jeet
    No mechanical parts.  I did have some mechanical parts on the schematic (just arrows with no pins) but I removed them to see if that would fix the problem - it did not.
    In one design, I ran the back annotation (PCB > Update Schematic) after renumbering refdes on pcb.  I get the expected preview as shown below.  When clicking Sync, though, it fails to update and the error message pops up in Capture, and the Capture session log displays the "physical error" info.
    I got the same when I ran the back annotate from Capture.
  • Jeet
    0 Jeet over 2 years ago in reply to passedpawn
    As it may need data sharing to debug this issue, I will be contacting you through separate channel of communication.
  • Jeet
    0 Jeet over 2 years ago in reply to Jeet
    As per our discussion after making the schematic and layout in sync and renaming the refdes in OrCAD X Presto and saving .brd you were able to back annotate the changes in OrCAD X Capture without getting any error.
