  2. Allegro X Capture CIS
  3. Capture Hierarchy- using global power pins for signal nets...
  • State Verified Answer
  • Subscribers 50
  • Views 4464
Capture Hierarchy- using global power pins for signal nets?
Lock2002
Lock2002 over 2 years ago
We have a RF design that we decided to use a hierarchical schematic. This is primarily to make it easier to follow (30+ pages). The designer added all ports for the RF paths, but we just realized that we are missing ports for all digital logic. I can add the ports, but it will make a mess of our pretty block diagram. I was considering replacing the off-page symbols with global power symbols. Can someone give me a reason not to do this?
  • Jeet
    Jeet over 2 years ago in reply to Lock2002 +1 verified
    If you place ground symbols instead of ports in a hierarchical block, the hierarchical pins will not get generated. This is because hierarchical pins are used to connect the ports of a hierarchical block…
  • Jeet
    0 Jeet over 2 years ago
    Off-page connectors carry nets (names) between schematic pages within the same schematic folder.
    Global Power symbols are used to make power nets globally across the schematic design.
    Off page connectors and global power symbols are two different types of symbols, they can’t be replaced from design cache. So, you will have to do it manually.
    Also, I want to understand if there is some particular requirement due to which you want to use place ground symbols instead of off page connectors.
  • Lock2002
    0 Lock2002 over 2 years ago in reply to Jeet
    I'm considering it because we are using the block diagram primarily to be able to flow the RF flow. If I have to add ports for digital controls it will really clutter the block diagram.
  • Jeet
    +1 Jeet over 2 years ago in reply to Lock2002
    If you place ground symbols instead of ports in a hierarchical block, the hierarchical pins will not get generated. This is because hierarchical pins are used to connect the ports of a hierarchical block to the ports of its parent block, and if there are no ports to connect, there will be no hierarchical pins.
    Hierarchical ports and hierarchical pins are used to connect the different levels of a hierarchical block to each other.
  • Wild
    0 Wild over 2 years ago in reply to Jeet
    I use this feature mentioned by Vishwajeet for local GND's,  such as single point ground,s then create a net short component and bring them out through the hierarchy using the ports.
