  2. Allegro X Capture CIS
  3. Wire error
  • Subscribers 50
  • Views 3387
Wire error
Flavio03
Flavio03 over 2 years ago
I can no longer connect the parts with the "wire" function. When I am on the first terminal, the red dot that allows the correct connection is not present, however on the second terminal it appears and so I am unable to make the connections correctly. Also the "net alias" doesn't automatically put itself on the wire when I get close to it. Can anyone tell me if I changed any settings by mistake or if I can fix it somehow?
  • Jeet
    0 Jeet over 2 years ago
    What are the Grid Reference settings you have set for the schematic page?
    Which version and hotfix of the tool you are using?
  • Flavio03
    0 Flavio03 over 2 years ago in reply to Jeet
    I'm using the academic free trial of Orcad X Professional Plus Capture CIS 2023 23.1
    I have never changed the settings or grid references of the schematic page, however my grid reference settings are these:
    horizontal count: 5, x numeric, x descending, width: 0,1 inches
    vertical count: 4, x alphabetic, x descending, width 0,1 inches
    border visible: x displayed, x printed
    grid reference visible: x displayed, x printed
    title block visible: x displayed, x printed
    x ANSI grid reference
    please tell me how can i fix the problem
  • Jeet
    0 Jeet over 2 years ago in reply to Flavio03
    I tried the same on 23.1 hotfix S005 with same grid settings I am not facing any issue in connectivity.
    Is this design specific issue or is happening with all designs?
