  2. Allegro X Capture CIS
  3. OrCAD Capture 17.4 P0001 crash when create new layout
  • State Verified Answer
  • Subscribers 50
  • Views 3922
Abdalla Saad
Abdalla Saad over 2 years ago
Dears,
I have finished schematics in Capture 17.4 P0001, The Netlists are created successfully, but when i am creating New layout for new PCB, the ORCAD Hang up at this point and crash.
I have tried to create the board file (*.brd) first in the allegro folder and then create New layout by pointing path to the newly generated pcb, but still the same issue.
Best Regards,
Abdalla Saad
  • Abdalla Saad
    Abdalla Saad over 2 years ago +1 verified
    Update (Issue Fixed) The issue caused by a space in the project directory path, after removing the space from the path, the new layout generated successfully.
  • VVRD
    0 VVRD over 2 years ago
    Hi Abdalla,
    Are you able to import generated netlist to the board?
    Thank you.
  • Abdalla Saad
    +1 Abdalla Saad over 2 years ago
  • Abdalla Saad
    0 Abdalla Saad over 2 years ago in reply to VVRD
    Hi VVRD,
    Thanks for your response.
    Issue Fixed after removing the space from the project path, and now i can import generated netlist to the board.
    Thanks, Have a nice day.
