  2. Allegro X Capture CIS
  3. How to select a specific net name for a net or signal from...
  • Subscribers 49
  • Views 4673
How to select a specific net name for a net or signal from multiple names in the design?
yugandhar
yugandhar over 2 years ago
OrCAD Capture CIS comes with a feature to change and select the specific net name to get transferred to the netlist.
The solution is to double-click on the wire or net, open the Property Editor window with the Schematic Nets tab active, select the desired net name from the drop-down list, click Apply, and close the Property Editor window. The selected net name will then be transferred to the netlist.
Hope this feature helps you synchronize the schematic design and board data.
Yugandhar.
