  2. Allegro X Capture CIS
  3. How to combine the instance and occurrence properties in...
  • State Verified Answer
  • Subscribers 50
  • Views 3476
How to combine the instance and occurrence properties in the edit object properties of Capture schematic
RohitRohan
RohitRohan over 2 years ago
Hai Community,
In the Edit Object Properties, I can see the properties as categorized into instance property and occurrence properties. (Below image for reference)
(I am assuming the black column is the instance properties and yellow column is the occurrence properties, do correct me if I am wrong about it)
How to merge both the yellow and black column, I want only the Black Column to be displayed in the Edit Object Properties.
Rohit Rohan
  • Akshay khosla
    Akshay khosla over 2 years ago +1 verified
    Hi Rohit Rohan, Yes, your understanding is correct, black column is the instance and yellow columns are the occurrences. You can hide the occurrence columns using "-" icon from instance header however…
  • Akshay khosla
    +1 Akshay khosla over 2 years ago
    Hi Rohit Rohan,
    Yes, your understanding is correct, black column is the instance and yellow columns are the occurrences. You can hide the occurrence columns using "-" icon from instance header however when you open the property editor again, it displays both the occurrence and instance columns again as there is a difference in Reference in both the columns.
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to Akshay khosla
    Hai Akshay,
    Thanks Blush
    Rohit Rohan
