  2. Allegro X Capture CIS
  3. How to check if the occurrence properties are different...
  • State Verified Answer
  • Subscribers 51
  • Views 5075
How to check if the occurrence properties are different from the instance properties
RohitRohan
RohitRohan over 2 years ago
Hai Community,
I have a schematic design where I can see the instance properties and occurrence properties in the edit object properties or edit properties, we know that any change in the instance properties will reflect in the occurrence properties.
Sometimes I see that the instance properties are not equal to occurrence properties, in that case is there any way to know that whether the occurrence properties are not the same as the instance properties, and how to find for which the properties have been changed. It will be very helpful to identify which schematic part properties have been changes so before pushing the occurrence properties to instance properties I can identify them and then push them to instance properties.
Rohit Rohan
  • Jeet
    Jeet over 2 years ago +1 verified
    When a design is annotated in instance mode, the part reference is assigned in the white/black column, representing instance mode of the property editor. A flat or simple hierarchical design is expected…
  • Jeet
    +1 Jeet over 2 years ago
    or simple hierarchical design is expected to have the same values in the white/black and
    yellow columns, this is the preferred mode of annotation for a flat or simple hierarchical
    design.
    For Flat and Simple Hierarchical Design--No part contains duplicate occurrence in a flat or simple hierarchical design. The
    property editor contains one white/black and one yellow column for every part and both
    contain the same value for all properties. By default, the yellow column is hidden for an
    instance mode design. You can click the plus sign to expand the yellow column.
    When a design is annotated in occurrence mode, the part reference is assigned/modified in the yellow column representing
    the occurrence mode of the property editor. At times, the occurrence value for a property may be picked from the instance
    column. Such columns appear striped.
    For Complex Hierarchical Design--The property editor includes a yellow column for each occurrence of a part. If a design
    contains three duplicate hierarchical blocks, for all the parts within that hierarchical
    block, the property editor will contain one white/black and three yellow columns.
    The Part Reference of parts in yellow columns (at the occurrence level) must be unique
    after the correct annotation of the design.
    You can see details about Instance and Occurrence Modes of Design Annotation in depth with following link:
    Article (20416530)
    Title: Understanding Instance and Occurrence Modes of Design Annotation
    URL: support.cadence.com/.../ArticleAttachmentPortal
    Let me know in case of any further questions on this.
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to Jeet
    Hai Sir,
    Thank you Blush
    Rohit Rohan
  • MM202410209619
    0 MM202410209619 over 2 years ago in reply to Jeet
    Deep Expertise Jeet
