  2. Allegro X Capture CIS
  3. Netlist is created even when footprint is not available
  • State Suggested Answer
  • Answers 1
  • Subscribers 51
  • Views 4306
Isha
Isha over 2 years ago
Earlier I used 17.2 software in which Netlist wouldn't be created if any single footprint is missing.
But now when I am using 17.4 software the Netlist gets created even if Footprints are missing.
It does throw a warning which could be avoided and the problem is identified when the board creation begins some components are missing.
Does anybody have a solution for this.
  • rg13
    rg13 over 2 years ago +1 suggested
    I checked it on 17.4 and netlister failed if PCB Footprint value is missing from any instance in the design. It shows error ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance C1: SCHEMATIC1…
  • rg13
    0 rg13 over 2 years ago
    It shows error  ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance C1: SCHEMATIC1, PAGE1 (2.00, 2.10) in session log.
    Which hotfix of SPB17.4 you are using? To know the version and hotfix details, go to Help > About menu in the tool.
  • Isha
    0 Isha over 2 years ago in reply to rg13
    I am using Hotfix S038
  • rg13
    0 rg13 over 2 years ago in reply to Isha
    You will be contacted by separate channel of communication in order to look into your issue regarding this post.
  • MM202410209619
    0 MM202410209619 over 2 years ago
    Isha I have made many designs in OrCAD and netlist cannot be possible if footprint is missing.
    Mechanical symbol can be the symbol
