  2. Allegro X Capture CIS
  3. OrCADX_23.1 / Schematic Constraint Manager problem: Components...
  • State Verified Answer
  • Subscribers 50
  • Views 3555
OrCADX_23.1 / Schematic Constraint Manager problem: Components list doesnt appear in Property field
grax
grax over 2 years ago
Hi
after generating the netlist and launching the Schematic Constraint Manager, all Nets are accessible but not the Components to be found in Properties > Components
Is this a bug?
I need to access to PINUSE property at schematic level, is there any other solution?
thanks
L
  • Jeet
    Jeet over 2 years ago in reply to grax +1 verified
    Try using following steps: 1. Invoke Constraint Manager form OrCAD Capture. 2. Select Properties tab. 3. Choose Objects > Filter > Uncheck Design Instance and Hit OK. 4. Now, you will be…
  • Jeet
    0 Jeet over 2 years ago
    Are you looking to transfer this Pinuse property on components from Constraint Manager at schematic level?
  • grax
    0 grax over 2 years ago in reply to Jeet
    thanks for your answer
    The problem is that the COMPONENT netlist doesnt show up on ORcadX Schemtic Constraint Manager
    Is this a bug?
  • Jeet
    +1 Jeet over 2 years ago in reply to grax
    4. Now, you will be able to view the components in the Properties sheet, as shown below.
    Let me know how it goes for you after performing the steps, are you able to see Components inside the Properties tab?
  • grax
    it works!
