  2. Allegro X Capture CIS
  3. Can't open library symbol .OLB create by 17.2 in version...
  • Subscribers 50
  • Views 1164
Can't open library symbol .OLB create by 17.2 in version 22.1
Votinh
Votinh over 2 years ago
I Can't open library symbol  .OLB create by 17.2 in version 22.1.
Please help me fix this error
  • Jeet
    0 Jeet over 2 years ago
    Do you have any backup (OBK) file of the library present in the same directory as your library? If you have the backup file rename the file to an .OLB extension and then try opening the library in version 22.1
    Try exporting the library file to Design XML and then import the file using Design XML and then try opening the library file in 22.1 version.
    Let me know how it goes for you after performing the steps, are you able to open the library in 22.1 version?
