  2. Allegro X Capture CIS
  3. Unable to open multiple DSN files from the file manager
  • Subscribers 50
  • Views 5417
Isha
Isha over 2 years ago
When I try to open the DSN file from the file manager it opens for the first file.
When I try to open another file from the file manager while the first file is open , to my surprise it doesn't open. Every time I will have to browse from the tool itself to open multiple files.
I am using OrCAD 23.1 software S006 hotfix
Earlier all other versions did not have this issue. In 23.1, I also tried with S002, S004 and S005 and the issue persists
Is there any setup to be made.
  • Jeet
    0 Jeet over 2 years ago
    This is not an issue. Multiple instances of OrCAD Capture cannot be opened at a time (in single session). Once tool is opened and its exe is running in task manager, you can open multiple designs using Browse options from main menu 'File > Open'. In single instance of the tool, you can open multiple design this way.
    Hope this helps!
  • Isha
    0 Isha over 2 years ago in reply to Jeet
    Thanks for replying Vishwajeet
    I am currently opening multiple designs with the Browse option itself.
    But some of my colleagues are able to open multiple files from the file manager so just want to know how is it possible
  • Jeet
    0 Jeet over 2 years ago in reply to Isha
    Which version and hotfix of the tool you are using?
    Are you using multiple versions of OrCAD Capture like 17.4, 22.1 or 23.1?
    Can you try with the sample schematic designs present at ->C:\Cadence\SPB_23.1\tools\capture\samples\Schematic
    Also, Can you try to re-browse the path and let me know if this helps.
  • Isha
    I am using 23.1 and S006 hotfix
    Yes, I am using OrCAD17.4 and 23.1 versions
    Also, tried doing the steps you have suggested yet I am unable to open multiple files at once
  • Jeet
    You will be contacted by separate channel of communication in order to look into your issue regarding this post.
