  2. Allegro X Capture CIS
  3. How to change 'Part Not Present' display value?
  • Subscribers 49
  • Views 1359
yugandhar
yugandhar over 2 years ago
While working with core design variants and exporting the part data in BOM (Bill of Materials) for schematic designs, do we have an option to change the display text of these parts as per our choice?
In Capture, we can set the text for the "not to be present components" in the variant BOM.
Go to Options > CIS Configuration > Setup and select the Administrative Preferences tab.
Under the Design Variants section, change the value of Part Not Present Display Value to the required value and click OK.
The part details for the schematic design will be represented as below in Variant View Mode.
Hope you find this feature helpful to use. Do share your inputs on how the option is helpful for your schematic designs.
Yugandhar.
