  2. Allegro X Capture CIS
  3. Capture OrcadX the command PCB > (Configure POWER NETS)...
  • State Verified Answer
  • Subscribers 50
  • Views 4128
Capture OrcadX the command PCB > (Configure POWER NETS) never works!
grax
grax over 2 years ago
Hi
the command MENU > PCB > Configure POWER NETS
NEVER WORKS!!
it is important to configure the POWER NETS in order to control Xnet generation
please explain why this doesnt work
  • grax
    grax over 2 years ago +1 verified
    Found the solution SI ANALYSIS > IDENTIFY DC NETS
  • Jeet
    0 Jeet over 2 years ago
    I tried the same at my end and on choosing PCB > Configure Power Nets it opens Assign Power Pins window at my end.
    Are you not getting this window at your end?
    You can see details about Assign Power Pins in depth at the following link >
    URL: OrCAD Capture User Guide -- Properties on Power Pins (cadence.com)
    Let me know in case of any further questions on this.
  • grax
    0 grax over 2 years ago in reply to Jeet
    SCHEMA is SELECTED, then
    PCB > Assign Power Pins == >No windows will open, nothings shows up
    besides
    EDIT > BROWSE > POWER PINS ==> no pins are shown regardless of the option selected
    It seems that there is a bug in OrcaX
    OrCAD X professional Plus Capture CIS
    23.1.S004 Wind SPB 64bit Edition
    I checked also with a RefDesign from NVIDA and it doesnt work neither and it is the same
    Pls help
    L
  • Jeet
    0 Jeet over 2 years ago in reply to grax
    Assign Power Pins command can be used on a component or on a design to view the invisible power pins of a single component or of all components in the designs.
     Can you try with the sample schematic designs present at ->C:\Cadence\SPB_23.1\tools\capture\samples\Schematic\Bench and check whether you are getting Assign Power Pins window or not on selecting PCB > Configure PCB Power Nets.
  • grax
    Hi, yes on your sample schematic it works so why it doesnt work on my design ?? (the windows never shows up)
  • Jeet
    Create a new component with the power pins and place the component on the schematic design and then select whether you are able to get the window.
