  2. Allegro X Capture CIS
  3. OrcadX Constraint Manager: cannot create PCS, it is gra...
  • State Verified Answer
  • Answers 1
  • Subscribers 51
  • Views 2826
OrcadX Constraint Manager: cannot create PCS, it is grayed
grax
grax over 2 years ago
Hi
after Netlist generation, I launch ConstraintManager from OrcadX capture
Unfortunately I cannot create any PCS since the button is grayed (See picture)
Why this?
Pls help
Best
  • grax
    grax over 2 years ago in reply to steve +1 verified
    Yes! Thanks!
  • steve
    0 steve over 2 years ago
    You need to either Import a Technology file that has been made in PCB Editor/Presto or back annotate (PCB - Update Schematic)  a board file once you are in a Constraint enabled flow. That will bring in the Default Physical and Spacing Constraints and then you can modify / add to them.
  • grax
    +1 grax over 2 years ago in reply to steve
    Yes! Thanks!
