  2. Allegro X Capture CIS
  3. unable to generate smart PDF in OrCAD Capture CIS
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 7370
RH202409037327
RH202409037327 over 2 years ago
I am trying to generate a smart PDF in OrCAD Capture CIS but I am getting an error (ORCAD-1332) which is missing Post Script Driver.
I have had this problem on 22.1. I have tried to install Ghostscript 32bit and 64bit , but the issue still happens.
could someone help me to fix the issue?
  • PatEscher
    PatEscher over 2 years ago +1 suggested
    Check if you have a postscriptdriver OrCADPS_22.1 installed in your printers. This is typically happening during the OrCAD installation If not the case, add a new PS based printer and then name it in the…
  • PatEscher
    0 PatEscher over 2 years ago
    If not the case, add a new PS based printer and then name it in the form
  • Akshay khosla
    0 Akshay khosla over 2 years ago
    Please try configuring the new windows printer setup using the steps as mentioned in the following article.
    Article (20497527)
    Title: Error ORCAP-1332 on doing File > Export PDF
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • RH202409037327
    0 RH202409037327 over 2 years ago in reply to PatEscher
    it's working now, thank you so much
