  2. Allegro X Capture CIS
  3. OrCAD EDM LOCK SYSTEM
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 2587
Isha
Isha over 2 years ago
I am using OrCAD EDM
When I check out for a particular design and working on it no other designer should be able to open the design
But what happens is even though I check out other users are able to access the design and make changes in it
Is there a way to lock the design
  • CadAP
    CadAP over 2 years ago +1 suggested
    Hi Isha, Please check what role is assigned to the user, also you can create e new roles with permission you want to grant to that group. Login with Admin profile and go to Admin-->Manager Users…
  • CadAP
    0 CadAP over 2 years ago
    Hi Isha,
    Login with Admin profile and go to Admin-->Manager Users-->Users Roles and create a Role with required permission.
    Hope this helps
