  2. Allegro X Capture CIS
  3. Will LIVEBOM support CIS relational database, soon?
  • Subscribers 49
  • Views 1982
gvellet
gvellet over 2 years ago
This is a question to Cadence. I've experimented with live BOM and it seems there is an important limitation. It analyses the BOM telling which part has an availability issue but LIVEBOM uses only the first manufacturer PN defined in the CIS database. In my CIS database, I have defined several alternate manufacturer PN for each part number specifically to protect against a single source shortage. It would be wonderful if Livebom could analyse every alternate manufacturer PN of each part number. And give a warning only when all the manufacturer PNs of a specific par number have an availability problem.
  • rg13
    0 rg13 over 2 years ago
    Yes it seems to be the case that it uses only first MPN defined in CIS. However, for other possibilities, checking it at my end.
