  2. Allegro X Capture CIS
  3. How to place a database part if the “Database Part” option...
  • Subscribers 49
  • Views 3305
How to place a database part if the “Database Part” option is not visible under the Place menu in Capture CIS
yugandhar
yugandhar over 2 years ago
In the 23.1 release, Hotfix 003 onwards, the Component Explorer interface provides an option to place the components from a CIS database.
Selecting CIS ODBC under Categories opens CIS Explorer, which enables you to place any CIS database part on a schematic.
To open CIS Explorer and access a database, select Place > Component > CIS ODBC.
Alternatively, you can press the Z shortcut key on the keyboard to open CIS Explorer directly and access a database.
Additionally, if you want to have the option visible in the Place menu and the right-click context menu of the schematic page, follow the steps below.
  • Go to Options > Extended Preferences > CIS and enable the “Show Place Database Part menu command” option.
The Database Part command will be visible in the Place menu as well as the right-click context menu on the schematic page.
Yugandhar.
