  2. Allegro X Capture CIS
  3. Lock Title block using tcl script
  • Subscribers 50
  • Views 2013
MK202410046732
MK202410046732 over 2 years ago
Hello everyone.
I use Page Customization tool to place title blocks on page during creation. But I want lock title blocks after placement. Please give me advice how to change tcl script to do that
  • CadAP
    0 CadAP over 2 years ago
    MK202410046732
    You can run the below command after placing the title block and also check status after running the lcok command:
     Menu "Edit::Lock" --> lock the object
    $varibale--> pass the variable that holds the db ID of the placed object.
    $variable IsObjLocked --> 1 means locked, 0- Means unlocked.
    Hope it helps.
