  2. Allegro X Capture CIS
  3. TCL problem when get net name of pin in hierarchy desig...
  • Subscribers 50
  • Views 2308
TCL problem when get net name of pin in hierarchy design
LL202411014740
LL202411014740 over 2 years ago
when I get net name of a pin in hierarchy design,I get the ref path name,name,number successfully ,but failed  in get net name
eg:  a Inst U1 with 3 Occ U1,U2,U3 in hierarchy  m1,m2,m3
design  -> block m2 -> Occ u2 --> Occ pin clk -> effective property
prop success:
      ref path: m2/u2/clk
        number: 20
fail:occ2 netname clk,not clk_m2
net name in orcad gui window:
inst.   occ1. occ2.    occ3
clk clk_m1 clk_m2 clk_m3
  • CadAP
    0 CadAP over 2 years ago
    LL202411014740
    Please copy the below code in text editor and save with .tcl extension.
    Now source in the capture command window;
    #Get pin and conneted netnames of hierachical blocks
    proc dumphierpinsnets {} {
    # global i
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lCount 0
    set lStatus [DboState]
    set lDesign [$lSession GetActiveDesign]
    set lSchi_Name [DboTclHelper_sMakeCString]
    set lNetNameCString [DboTclHelper_sMakeCString]
    set lPinNameCString [DboTclHelper_sMakeCString]
    set lNameCString [DboTclHelper_sMakeCString]
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    #get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    set lPage_Name [DboTclHelper_sMakeCString]
    while { $lView != $lNullObj} {
    #dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    $lSchematic GetName $lSchi_Name
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    #get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    # puts [DboTclHelper_sGetConstCharPtr $lSchi_Name]
    while {$lPage!=$lNullObj} {
    set lPartInstsIter [$lPage NewPartInstsIter $lStatus]
    #get the first part inst
    set lInst [$lPartInstsIter NextPartInst $lStatus]
    while {$lInst!=$lNullObj} {
    #dynamic cast from DboPartInst to DboDrawnInst
    set lDrawnInst [DboPartInstToDboDrawnInst $lInst]
    if {$lDrawnInst != $lNullObj} {
    $lDrawnInst GetName $lNameCString
    puts [DboTclHelper_sGetConstCharPtr $lNameCString]
    set lIter [$lDrawnInst NewPinsIter $lStatus]
    #get the first pin of the part
    set lPin [$lIter NextPin $lStatus]
    while {$lPin !=$lNullObj } {
    #placeholder: do your processing on $lPin
    $lPin GetPinName $lPinNameCString
    set lNet [$lPin GetNet $lStatus]
    $lNet GetNetName $lNetNameCString
    # puts [DboTclHelper_sGetConstCharPtr $lNameCString]
    puts "Pin_Name:== [DboTclHelper_sGetConstCharPtr $lPinNameCString]"
    puts "Net_Name:== [DboTclHelper_sGetConstCharPtr $lNetNameCString]"
    #get the next pin of the part
    delete_DboPartInstPinsIter $lIter
    #placeholder: do your processing on $lDrawnInst
    #get the next part inst
    #placeholder: do your processing on $lPage
    # $lPage GetName $lPage_Name
    # puts [DboTclHelper_sGetConstCharPtr $lPage_Name]
    #get the next page
    #puts $lSchematic
    #get the next schematic view
    delete_DboLibViewsIter $lSchematicIter
    delete_DboSchematicPagesIter $lPagesIter
    dumphierpinsnets
    Hope it helps!
