  2. Allegro X Capture CIS
  3. CIS Explorer: relation table filtered always using the Part...
  • Subscribers 43
  • Views 1786
CIS Explorer: relation table filtered always using the Part Number field value.
eddoh
eddoh over 1 year ago
I'd like to view detail information  about a package as a relational table.when clicking on a row describing my part,
In my database I am storing the details in a Packages table, having a key field "Package"
I have set up the relationship table between the main table, which has a matching PACKAGE field, by specifying PACKAGE in the drop down and PACKAGES as relational table.
What happens is that, when I click on a row of the main table, CIS is looking for a matching table in the PACKAGES table using the PART NUMBER value in the filter condition - as I see from the SQL log of my database [i.e. SELECT .... FROM PACKAGES WHERE PACKAGE='NE555' for instance)
I think this is a bug, I wonder if someone has a solution.
Thanks!
  • Jeet
    0 Jeet over 1 year ago
    How much time it takes to load the Package in Relational Table and where is your database (.dbc) database present on server or is configured locally?
    Which version and hotfix of the tool you are using?
  • eddoh
    0 eddoh over 1 year ago in reply to Jeet
    my dbc is in a local folder, Not sure what you mean by the time question. Once the record is selected, the query to the server (located on a different host) is instantaneous. The connection is via a configured ODBC.
    I am using Orcad X 24.1 P001.
  • eddoh
    0 eddoh over 1 year ago in reply to eddoh
    By this, of course, I meant I have set that up in the Orcad:CIS configfuration :Configure database::Relational Database panel, selecting the table holding the part details and choosing its PACKAGE field and specifying PACKAGES as relational table.
