  2. Allegro X Capture CIS
  3. Copying text from CIS Explorer tables
  • State Verified Answer
  • Replies 7
  • Subscribers 52
  • Views 3450
pertinax
pertinax over 1 year ago
Hi, I often find myself wanting to copy e.g., part numbers, values or similar from the CIS Explorer window. Sadly, this isn't possible. Has anyone found a workaround?
One scenario would be when trying to find the exact part on DigiKey. One would select the component in the schematic and press CTRL+D to view the component in CIS and from there copy the DigiKey partnumber into the web browser. Right now I have to manually transcribe the part number into the browser using my keyboard, this is a PITA.
Thanks!
  • Jeet
    Jeet over 1 year ago in reply to pertinax +2 verified
    Select the desired fields by holding down the Ctrl key or the Shift key or you can select entire row at once by selecting on 1 Once the fields are selected, copy them using the keyboard shortcut Ctrl …
  • Robert Finley
    0 Robert Finley over 1 year ago in reply to pertinax
    With great power comes great responsibility.
    Worked with a junior engineer who abused new-part creation privs and edited existing CIS parts to change values because he hated the idea of re-linking.   Didn't realize BOM info is cached.  Broke other projects that were released in ways we didn't notice right away.
    Cool feature in EMA's Component Information Portal?
    Revision history.
  • pertinax
    0 pertinax over 1 year ago in reply to Jeet
    This does indeed work. What threw me off was the use of Ctrl+Ins for copying. I hadn't used this key combo for copying before. At least in modern times... When I tried your suggestion the first time, I automatically changed the keys to Shift+Ins which will of course paste.
    It's a real plus that you can copy a full row at a time. Now I will have a warm fuzzy feeling each time I copy something from CIS ;-)
    Thanks!
