  2. Allegro X Capture CIS
  3. Copying text from CIS Explorer tables
  • State Verified Answer
  • Replies 7
  • Subscribers 52
  • Views 3449
pertinax
pertinax over 1 year ago
Hi, I often find myself wanting to copy e.g., part numbers, values or similar from the CIS Explorer window. Sadly, this isn't possible. Has anyone found a workaround?
One scenario would be when trying to find the exact part on DigiKey. One would select the component in the schematic and press CTRL+D to view the component in CIS and from there copy the DigiKey partnumber into the web browser. Right now I have to manually transcribe the part number into the browser using my keyboard, this is a PITA.
Thanks!
  • Jeet
    Jeet over 1 year ago in reply to pertinax +2 verified
    Select the desired fields by holding down the Ctrl key or the Shift key or you can select entire row at once by selecting on 1 Once the fields are selected, copy them using the keyboard shortcut Ctrl …
  • Jeet
    0 Jeet over 1 year ago
    Can you try with Ctrl + Insert key combination in CIS explorer and then try Ctrl + V to paste the data.
    Let me know how it goes for you after trying this combination?
  • pertinax
    0 pertinax over 1 year ago in reply to Jeet
    Thanks for the suggestion. I tried Ctrl + Insert and this actually pasted information into the table! :-D  But I want to copy it from the table.
  • Siliconmaster
    0 Siliconmaster over 1 year ago in reply to Jeet
    This is helpful
  • pertinax
    0 pertinax over 1 year ago in reply to Siliconmaster
    Note that when pasting, the information is not written to the database. So, sadly, not very helpful... :-P
  • Jeet
    +1 Jeet over 1 year ago in reply to pertinax
    Select the desired fields by holding down the Ctrl key or the Shift key or you can select entire row at once by selecting on 1 Once the fields are selected, copy them using the keyboard shortcut Ctrl +Insert. Then, navigate to the desired location and paste the copied fields using the keyboard shortcut Ctrl +V.
    Now, navigate to the desired location and paste the copied fields using the keyboard shortcut Ctrl +V.
    • Vote Up +2 Vote Down
