  2. Allegro X Capture CIS
  3. Removing Hierarchical blocks on root, does deleting a block...
  • State Verified Answer
  • Subscribers 51
  • Views 1822
Removing Hierarchical blocks on root, does deleting a block on the root page also delete the schematic page?
CS20250218279
CS20250218279 over 1 year ago
I noticed when I delete the hierarchical blocks that are used multiple times on the Top level root page, it deletes the occurrences on the following schematic pages which i expected.
Then when deleting a block that's only used once, it doesn't delete the schematic page on the left panel. For the blocks that are only used once, do I have to delete the page on the left panel to remove it?
  • Jeet
    Jeet over 1 year ago +1 verified
    A hierarchical block is a representation of a schematic folder, which is attached to the hierarchical block. Deleting a hierarchical block from the top schematic will not delete the schematic from the…
  • Jeet
    0 Jeet over 1 year ago
    A hierarchical block is a representation of a schematic folder, which is attached to the hierarchical block. Deleting a hierarchical block from the top schematic will not delete the schematic from the design. You can delete the schematic folder from the project manager.
    In the below image, I have placed A1, A2 and A3 hierarchical blocks which are pointing to BOTTOM schematic folder and BLOCK1 is pointing to BOTTOM1 schematic folder, if I delete BLOCK1 block from Top schematic folder it will not delete the BOTTOM1 schematic folder from the schematic design.
    Let me know if you have any further questions.
