  2. Allegro X Capture CIS
  3. How can I use a tcl script to update the modified information...
  • State Verified Answer
  • Subscribers 50
  • Views 5218
How can I use a tcl script to update the modified information from library to Design Cache which is in .DSN project?
Morgan
Morgan over 1 year ago
Hi Community,
If I have modified the part name and footprint in the library, for example, the part name has been changed from MAX3232EIDR to MAX3232EIPWRG4, and the footprint has been changed from SOIC16 to TSSOP16, how can I use a tcl script to update them from library to Design Cache which is in .DSN project? (with Cadence Capture CIS)
The following tcl script is Get Part Value from schematic and Get  SourcePackage  Name from Design Cache.
#Get Part Value from schematic
set lPartValueNameStr [DboTclHelper_sMakeCString]
$pPlacedInst GetPartValue $lPartValueNameStr
set lPartValueName [DboTclHelper_sGetConstCharPtr $lPartValueNameStr]
puts "lPartValueName : $lPartValueName"
#Get  SourcePackage  Name from Design Cache
set lCachedPartValueNameStr [DboTclHelper_sMakeCString]
$pPlacedInst GetSourcePackageName $lCachedPartValueNameStr
set lCachedPartValueName [DboTclHelper_sGetConstCharPtr $lCachedPartValueNameStr]
puts "lCachedPartValueName : $lCachedPartValueName"
Morgan Brown
  • CadAP
    CadAP over 1 year ago +1 verified
    Morgan Below proc will help to get the cached lib property. You can filter out the part from updated library based on attribute match from the part present in cached lib and then use below API to replace…
  • Morgan
    Morgan over 1 year ago in reply to CadAP +1
    Hi CadAP, Thanks for the code, but I'm not very familiar with the syntax of tcl database command, can you tell me how to use ReplaceCache and showCacheEntries?help me please! Also, can you provide…
  • CadAP
    CadAP over 1 year ago in reply to Morgan +1 verified
    HI Morgan, Procedure (prco) share in the above is used to get all the properties of cached part. You can take on which common property you need to check in the library which you used to replace cache…
  • Morgan
    0 Morgan over 1 year ago in reply to CadAP
    Thank you CadAP, it's useful for me.
