  2. Allegro X Capture CIS
  3. How can I use a tcl script to update the modified information...
  • State Verified Answer
  • Subscribers 50
  • Views 5217
How can I use a tcl script to update the modified information from library to Design Cache which is in .DSN project?
Morgan
Morgan over 1 year ago
Hi Community,
If I have modified the part name and footprint in the library, for example, the part name has been changed from MAX3232EIDR to MAX3232EIPWRG4, and the footprint has been changed from SOIC16 to TSSOP16, how can I use a tcl script to update them from library to Design Cache which is in .DSN project? (with Cadence Capture CIS)
The following tcl script is Get Part Value from schematic and Get  SourcePackage  Name from Design Cache.
#Get Part Value from schematic
set lPartValueNameStr [DboTclHelper_sMakeCString]
$pPlacedInst GetPartValue $lPartValueNameStr
set lPartValueName [DboTclHelper_sGetConstCharPtr $lPartValueNameStr]
puts "lPartValueName : $lPartValueName"
#Get  SourcePackage  Name from Design Cache
set lCachedPartValueNameStr [DboTclHelper_sMakeCString]
$pPlacedInst GetSourcePackageName $lCachedPartValueNameStr
set lCachedPartValueName [DboTclHelper_sGetConstCharPtr $lCachedPartValueNameStr]
puts "lCachedPartValueName : $lCachedPartValueName"
Morgan Brown
  • CadAP
    CadAP over 1 year ago +1 verified
    Morgan Below proc will help to get the cached lib property. You can filter out the part from updated library based on attribute match from the part present in cached lib and then use below API to replace…
  • Morgan
    Morgan over 1 year ago in reply to CadAP +1
    Hi CadAP, Thanks for the code, but I'm not very familiar with the syntax of tcl database command, can you tell me how to use ReplaceCache and showCacheEntries?help me please! Also, can you provide…
  • CadAP
    CadAP over 1 year ago in reply to Morgan +1 verified
    HI Morgan, Procedure (prco) share in the above is used to get all the properties of cached part. You can take on which common property you need to check in the library which you used to replace cache…
  • CadAP
    0 CadAP over 1 year ago
    Morgan
    You can filter out the part from updated library based on attribute match from the part present in cached lib and then use below API to replace cache:
    ReplaceCache(OldPackageOrSymbolName, OldLibName, NewName, NewLibName,
    Class : DboLib(DboBaseObject):
    bUpdateCache = 0, bPreserverefDes = 0) : returns DboState
    Parameters:
    OldPackageOrSymbolName: CString
    OldLibName: CString
    NewName: CString
    NewLibName: CString
    bUpdateCache: int
    bPreserverefDes: int
    proc showCacheEntries { pDesign } {
    set lPrpName [DboTclHelper_sMakeCString]
    set lPrpValue [DboTclHelper_sMakeCString]
    set lPrpType [DboTclHelper_sMakeDboValueType]
    set lEditable [DboTclHelper_sMakeInt]
    set cptr DboTclHelper_sGetConstCharPtr
    set lCacheNameCStr [DboTclHelper_sMakeCString]
    set lCacheLibNameCStr [DboTclHelper_sMakeCString]
    set lCachePropNameCStr [DboTclHelper_sMakeCString "Source Package"]
    set lCacheValNameCStr [DboTclHelper_sMakeCString]
    set lStatus [DboState]
    set lCacheObjectsIter [$pDesign NewCachesIter $lStatus $::IterDefs_ALL]
    set lCachedObject [$lCacheObjectsIter NextCachedObject $lStatus]
    while { $lCachedObject!= "NULL" } {
    set lCachedLibObject [DboBaseObjectToDboLibObject $lCachedObject]
    set lPropsIter [$lCachedLibObject NewEffectivePropsIter $lStatus]
    set lStatus [$lPropsIter NextEffectiveProp $lPrpName $lPrpValue $lPrpType $lEditable]
    while {[$lStatus OK] == 1} {
    if {[$cptr $lPrpName] != ""} {
    puts "\tName=[$cptr $lPrpName] Value= [$cptr $lPrpValue] "
    delete_DboEffectivePropsIter $lPropsIter
    # $lStatus -delete
    # puts "Value: = [DboTclHelper_sGetConstCharPtr $lCacheValNameCStr]"
    # $lCachedObject GetName $lCacheNameCStr
    # $pDesign GetSourceLibName $lCacheNameCStr $lCachedLibObject $lCacheLibNameCStr
    # puts -nonewline "[DboTclHelper_sGetConstCharPtr $lCacheNameCStr] : "
    delete_DboDesignCachesIter $lCacheObjectsIter
    $lStatus -delete
    Hope it helps.
    Do let me know if you require any help.
  • Morgan
    0 Morgan over 1 year ago in reply to CadAP
    Hi CadAP,
    • Thanks for the code, but I'm not very familiar with the syntax of tcl database command, can you tell me how to use ReplaceCache and showCacheEntries?help me please!
    • Also, can you provide some details about the Capture Database TCL Command, especially those classes and commands? I found the OrCAD_Capture_TclTk_Extensions_Revision1.2 file, but it is too crude, and there is no description of the proc parameters in Appendix A, Appendix B, and Appendix C.
  • CadAP
    +1 CadAP over 1 year ago in reply to Morgan
    HI Morgan,
    Procedure (prco) share in the above is used to get all the properties of cached part. You can take on which common property you need to check in the library which you used to replace cache par.
    Please check the page no-23 OrCAD_Capture_TclTk_Extensions_Revision1.2, you will get the library hierarchy as well as design hierarchy.
    For more information on library and design hierarchy, please refer to page 23 of the OrCAD Capture Tcl/Tk Extensions Revision 1.2 document. This document provides details on how to access different classes and use their APIs to retrieve specific information.
    For example:
    set lCacheObjectsIter [$pDesign NewCachesIter $lStatus $::IterDefs_ALL]  --> It returns DboLibCachesIter , Now in pdf I will search for class DboLibCachesIter .
    I captured few api under that class from the pdf.
    START class DboLibCachesIter(TBaseDboLibChangedObjectsIter):
    NextCachedObject(status) : returns DboBaseObject
    Class : DboLibCachesIter(TBaseDboLibChangedObjectsIter):
    Now I will use api NextCachedObjectto get the cached object like below:
    set lCachedObject [$lCacheObjectsIter NextCachedObject $lStatus] --> returns DboBaseObject, now i'll find api under DboBaseObject and use those.
    By following this process, you can navigate through the class hierarchy and use the available APIs to retrieve the desired information.
    Please check the below article how cached parts are replaced from a library.
    Article (20512519) Title: How to update the design cache library path to a new library path
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009mMUXEA2
    Hope this is helpful for you.
  • Morgan
    Hi CadAP,
    Can you help me, Copy the content of the article and put it here? Thank you very much.
  • CadAP
    0 CadAP over 1 year ago in reply to Morgan
    Morgan
    Find the code below:
    Please update the variable `lNewLibpath` to point to the specific directory where your `.olb` files are located, replacing the current value with your desired file path."
    #Replace Cache object from a new library path
    namespace eval readOlb {} {
    # variable dir [file normalize [info script]]
    set lNewLibpath {C:\Cadence\SPB_23.1\tools\capture\library}
    regsub -all {\\} $lNewLibpath {/} dirName
    # variable dirName [file dirname $dir]
    catch { variable fileData [glob -directory $dirName *.olb] } filereaderror
    proc readOlb::updateAllCacheParts {} {
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lDesign [$lSession GetActiveDesign]
    set lNameCString [DboTclHelper_sMakeCString]
    set lSrcLibPathCS [DboTclHelper_sMakeCString]
    set lDesignCacheIter [$lDesign NewCachesIter $lStatus]
    set lCachedObject [$lDesignCacheIter NextCachedObject $lStatus]
    set lPartName [DboTclHelper_sMakeCString]
    set updatedPartList {}
    set counter 0
    # set lContLib [$lCachedLibObject GetContainingLib]
    # # set llibname [$lSession GetLib $lContLib $lStatus ]
    while {$lCachedObject != $lNullObj} {
    $lContLib GetName $lPartName
    $lCachedLibObject GetSourceLibName $lSrcLibPathCS
    # $lCachedObject GetPathName $lPartName "/"
    set obj [$lCachedObject GetName $lNameCString]
    set lGetPartName [DboTclHelper_sGetConstCharPtr $lNameCString]
    # set lGetPartName [DboTclHelper_sGetConstCharPtr $lNameCString]
    # puts [DboTclHelper_sGetConstCharPtr $lPartName]
    set srcLibPath [file normalize [DboTclHelper_sGetConstCharPtr $lSrcLibPathCS] ]
    # puts [file normalize $srcLibPath]
    # puts $lGetPartName
    foreach libPath $readOlb::fileData {
    # puts $libPath
    set lNewLibPath [DboTclHelper_sMakeCString $libPath]
    set lDboLibrary [DboSession_GetLib $lSession $lNewLibPath $lStatus]
    # puts $lNewLibPath
    # puts $lDboLibrary
    lappend libpathlist $lDboLibrary
    if {$lDboLibrary != $lNullObj || $srcLibPath != $lNullObj} {
    set lIsPackageExits [$lDboLibrary PackageExists $lNameCString $lStatus]
    # puts $lIsPackageExits
    if {$lIsPackageExits == 1 && [lsearch $updatedPartList $lGetPartName] < 0 && $srcLibPath != $libPath } {
    # puts $srcLibPath
    # puts $libPath
    $lContLib ReplaceCache $lNameCString $lSrcLibPathCS $lNameCString $lNewLibPath
    lappend updatedPartList "CachePartName:== $lGetPartName Cache_NewLocation:= $libPath"
    $lContLib MarkModified
    $lSession MarkAllLibForSave $lContLib
    $lSession SaveLib $lContLib
    incr counter
    $lSession RemoveLib $lDboLibrary
    delete_DboDesignCachesIter $lDesignCacheIter
    set lDesignPath [DboTclHelper_sMakeCString]
    $lDesign GetName $lDesignPath
    set lDesignNameindex [string last "\\" [DboTclHelper_sGetConstCharPtr $lDesignPath]]
    set lDesignName [string range [DboTclHelper_sGetConstCharPtr $lDesignPath] [expr {$lDesignNameindex +1}] end]
    # puts $lDesignName
    if {$counter > 0} {
    puts "++++++++=========Saving the Design===========+++++++++++"
    catch {SelectPMItem "./$lDesignName"}
    catch {Menu "File::Save"}
    ClearSessionLog
    DboState_WriteToSessionLog "[DboTclHelper_sMakeCString "Below Cache Parts have been updated:"]"
    capDisplayMessageBox "Successfuly updated the Cache Library Location.Check Session Log For Informations" "INFORMATION!"
    puts $updatedPartList
    foreach part $updatedPartList {
    # puts $part
    if {$counter > 0} {
    DboState_WriteToSessionLog "[DboTclHelper_sMakeCString "$part"]"
