  2. Allegro X Capture CIS
  3. Orcad capture 17.2 all pages do not print to PDF
  • State Suggested Answer
  • Replies 9
  • Answers 1
  • Subscribers 45
  • Views 4393
avant
avant 9 months ago
Something changed recently. When I try to print a PDF from Orcad 17.2, all options in the panel are blank. I fill in the options and only one page will print. Reopening the schematic, all options are blank again.
If I open the schematic in 17.4, the print options are checked and all pages print.
It seems like there may be a config file for 17.2 that is corrupt and I cannot change?
Any idea what and where to look into?
  • Jeet
    0 Jeet 9 months ago
    Can you share a snapshot from File > Print of version 17.2, what options are blank?
  • avant
    0 avant 9 months ago in reply to Jeet
    All options are blank.
  • Jeet
    0 Jeet 9 months ago in reply to avant
    Are you able to select Scale and Print quality or any other options in Print dialog box ?
    Can you try File > Print Preview and let me know how it is coming up?
  • avant
    I can select all of the boxes, but they after closing Orcad, they are all blank again.
    Preview shows only one printed sheet.
    I can pick one schematic sheet and print it, but not all sheets.
    I suspect there's a config file somewhere I need to fix.
    Orcad version 17.4 works fine for me, it's just an extra hassle for me to use.
  • Jeet
    As it may need data sharing to debug this issue, I have contacted you through separate channel of communication.
