  2. Allegro X Capture CIS
  3. How to permanently change the front size of the Capture...
  • Subscribers 50
  • Views 2342
How to permanently change the front size of the Capture Command Window (the font size is too small)
Morgan
Morgan over 1 year ago
Hi Community,
How to permanently change the front size of the Capture Command Window (the font size is too small), so that it will not be restored to the default value the next time it is launched.
  • Jeet
    0 Jeet over 1 year ago
    Right click inside Command Window in OrCAD Capture and choose Font you will get Font dialog box as below and you change the Font for current session>
    You can change the font from here for Command Window, let me check where are these settings stored and if there is any way by which we can change the font permanently.
  • Morgan
    0 Morgan over 1 year ago in reply to Jeet
    Hi Jeet,
    Thank you very much, but this way can't change the font permanently, it will be restored to the default value when the next time launched.
  • ShouldEast
    0 ShouldEast over 1 year ago in reply to Morgan
    [deleted]
  • Morgan
    0 Morgan over 1 year ago in reply to ShouldEast
    Hi ShouldEast,
    I don't set it to default, there is no such option. Do you know how to set it to default?
