  2. Allegro X Capture CIS
  3. Howto avoid that Register Action on a schematic makes the...
  • Subscribers 49
  • Views 1494
Howto avoid that Register Action on a schematic makes the Page dirty
PatEscher
PatEscher over 1 year ago
through tcl customization we want to add a RMB action on the schematic page.
Unfortunately, the page is directly flagged as modified once we execute the Action.
Is there any way to avoid this?
This is the code we use.
The idea was to check if the page is already dirty (because of some modification done by the user before) and if not, we reset the dirty flag:
But when entering the callback "test2", the page is already dirty.
namespace eval ::testMenu {
proc test1 {args} {
return 1
proc test2 {args} {
puts "clicked"
RegisterAction "MenuTest" "::testMenu::test1" "" "::testMenu::test2" "Schematic"
  • CadAP
    0 CadAP over 1 year ago
    PatEscher
    Can you try below code:
    Select a page in PM tree and source below code:
    set lStatus [DboState]
    set lSelectedPage [GetSelectedPMItems]
    set lModifiedTime [$lSelectedPage GetModifyTime $lStatus]
    set lDboLib [$lSelectedPage GetContainingLib]
    set lModifiedCString [$lDboLib TimeToString $lModifiedTime]
    puts "[DboTclHelper_sGetConstCharPtr $lModifiedCString]"
    So, getting the exact day and date you can decide what whether to reset the flag or not.
    Hope this helps!
  • PatEscher
    0 PatEscher over 1 year ago in reply to CadAP
    Hi CadAP,
    not sure where to put this. Into the Action Callback?
    for me it seems that modifying the page when the call back is executed (even if we do a no-op) is a bug. I already reported a case on it.
    And does it work with my use case?
    I have a page open and then select a symbol. Then I do the RMB --> More --> MenuTest my callback should then simply call e.g. a Browser
    The problem is, that once the callback is executed, the page is shown as modified.
    So what is your code doing exactly? It is reading out the ModifyTime of the page? but based on what? the last save operation of the page?
    Thanks for your help,
    Patrick
  • PatEscher
    0 PatEscher over 1 year ago in reply to PatEscher
    CadAP
    so we found some way to identify if the page was modified or not.
    But currently we are struggling  with reseting this modified state
    Can you provide some tcl code or routines to reset the modified flag of the page?
    Worst case it would be possible to save only this page (but certainly not the full design or other pages, as there might be some other changes). Can you provide some examples?
    We tested a few tcl commands like clearModified() but doesn#t seem to work
    thanks
    Patrick
