  2. Allegro X Capture CIS
  3. Impossible to modify color of a part in occurrence
  • State Suggested Answer
  • Answers 1
  • Subscribers 51
  • Views 1880
Adam
Adam over 1 year ago
In Orcad X 24.1-2024-S003
In Hierarchical design, if i have multiple blocks, i can select a part and click right to open "Edit proprieties"
In the "Property Editor" there is the Property "Color" that permit to modify color of the all instance or any occurrence.
If i modify the color of a specific occurrence nothing happen.
Can someone handle this bug ?
Thank-you
  • Adam
    Adam over 1 year ago in reply to oldmouldy +1 suggested
    It is possible to up it to developers ? Because the only way to custom occurrences is to use BOM variants and because it's not possible to modify schematic in variant view, it is not always a great solution…
  • Jeet
    0 Jeet over 1 year ago
    I tried this at my end and I am able to change the color of occurrence without any issues, is it a schematic design specific issue?
  • Adam
    0 Adam over 1 year ago in reply to Jeet
    No, i tried also with a new project, same behavior
  • oldmouldy
    0 oldmouldy over 1 year ago in reply to Jeet
    I would say that, whilst it is possible to change the assigned color property value within the Occurrences properties, the actual color displayed is always derived from the color property value assigned to the Instances.
  • Adam
    0 Adam over 1 year ago in reply to oldmouldy
    Because the only way to custom occurrences is to use BOM variants and because it's not possible to modify schematic in variant view, it is not always a great solution.
