  2. Allegro X Capture CIS
  3. How to automatically place an off-page connector name from...
  • State Verified Answer
  • Replies 7
  • Subscribers 52
  • Views 6652
How to automatically place an off-page connector name from a net alias?
FB202502193638
FB202502193638 over 1 year ago
I captured a schematic and assigned a 'net alias' to every net. However, I now realize that I need to connect these nets to anothers pages. So, I added an 'off-page connector,' but it does not automatically take the value of the 'net alias.'
I tried copying and pasting the spreadsheet, it does not work and rewrite each off-page connector is time-consuming for 20 schematic pages.
  • What is the correct procedure to automatically rename an off-page connector with the same net alias value?
Allegro X 23.1 Capture CIS
Thanks for your help,
-Fabrizio
  • steve
    steve over 1 year ago +2 verified
    There is a free app that can be installed called CoolEditBox that has many utilities that help with this type of thing. Check out Download the EDAisWare CoolEditBox App - OrCAD Software Apps and Extensions…
  • steve
    +1 steve over 1 year ago
    There is a free app that can be installed called CoolEditBox that has many utilities that help with this type of thing. Check out Download the EDAisWare CoolEditBox App - OrCAD Software Apps and Extensions | EMA Store
    • Vote Up +2 Vote Down
  • oldmouldy
    0 oldmouldy over 1 year ago
    EDA Is, one of the Cadence Channel Partners, has the Cool Edit Box. If you reach out to them, or your Cadence Channel Partner, you should be able to obtain it. Also, you don't need both the Net Alias and the Off-Page Connector / Hierarchical Port named since the Net Name will be inherited from the attached Off-Page Connector / Hierarchical Port.
  • CadAP
    0 CadAP over 1 year ago
    FB202502193638
    I have created a sample script below which will applies the netalis name to offpage.
    Select a .dsn from the PM(project manager) and source the code.
    # ##Getting alisa of the wires.
    set lNets [CapFindObjects $COrFindFilterDlg_NETS {*}]
    set lStatus [DboState]
    # set lAliasName [DboTclHelper_sMakeCString]
    # set lNetName [DboTclHelper_sMakeCString]
    set lOffpageNameCS [DboTclHelper_sMakeCString]
    set lNullObj NULL
    foreach lNet $lNets {
        set lNet [lindex $lNet 0]
        set lWiresIter [$lNet NewWiresIter $lStatus]
        #get the first wire
        set lWire [$lWiresIter NextWire $lStatus]
        while {$lWire != $lNullObj} {
            puts $lWire
            $lWire GetNetName $lNetName
            $lNet GetName $lSchiNetName
            set lObjectType [$lWire GetObjectType]
            if {$lObjectType == $::DboBaseObject_WIRE_SCALAR} {
                set lAliasIter [$lWire NewAliasesIter $lStatus]
                # #get the first alias of wire
                set lAlias [$lAliasIter NextAlias $lStatus]
                while { $lAlias!=$lNullObj} {
                    #placeholder: do your processing on $lAlias
                    $lAlias GetName $lAliasName
                set lOffPagesIter [$lWire NewOffPageConnectorsIter $lStatus]
                #get the first off-page of the page
                set lOffPage [$lOffPagesIter NextOffPageConnector $lStatus]
                while {$lOffPage!=$lNullObj} {
                    #placeholder: do your processing on $lOffPage
                    #get the next off-page of the page
                    # $lOffPage GetName $lOffpageNameCS
                    $lOffPage SetName $lAliasName
                    # puts "offpage: = [DboTclHelper_sGetConstCharPtr $lOffpageNameCS]"
                delete_DboWireOffPageConnectorsIter $lOffPagesIter
            #get the next wire
            delete_DboWireAliasesIter $lAliasIter
    Hope this helps.
  • gvellet
    0 gvellet over 1 year ago in reply to steve
    Here is my personal experience with CoolEditBox.
    CoolEditBox is old (2016) and unsupported by EDA.
    CoolEditBox is not compatible with Orcad 22.1, 23.1 or 24.1.
    TCL source code is encrypted, we cannot fix the bug.
  • steve
    0 steve over 1 year ago in reply to gvellet
    Interesting.... this just works for me using 24.1 S003.
