  2. Allegro X Capture CIS
  3. Using Hierarchical Blocks
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 1067
CS20250218279
CS20250218279 over 1 year ago
If I am using a hierarchical block design on the root page, and I use 2 of the same blocks like the below image. If I go into the page that has the components, and I remove a resistor on Page A but want to keep the resistor on Page B, is that possible? Do i need to instead create a different block so that removing the resistor does not affect the second block?
  • Akshay khosla
    Akshay khosla over 1 year ago +2 suggested
    Unfortunately, it is currently not possible to achieve this as both H-blocks reference the same schematic folder. To have a different root schematic, you would need to create a new H-block that points…
  • Akshay khosla
    0 Akshay khosla over 1 year ago
    Unfortunately, it is currently not possible to achieve this as both H-blocks reference the same schematic folder. To have a different root schematic, you would need to create a new H-block that points to a separate schematic folder.
    Additionally, a feature enhancement request has already been submitted to implement this functionality.
    • Vote Up +2 Vote Down
