  2. Allegro X Capture CIS
  3. Adding Part height information in orcad schematic
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 1210
VG20250603525
VG20250603525 over 1 year ago
Hi
  Adding Part height information in OrCAD schematic, and same information to carry from schematic to layout and assign height information property.
Regards
Win
  • TechnoBobby
    TechnoBobby over 1 year ago +2 suggested
    Hi VG20250603525 , To carry Part Height information from the schematic to layout in OrCAD Capture and Allegro, follow these steps: 1. Add HEIGHT property to parts in the schematic: • Select the part, right…
  • TechnoBobby
    0 TechnoBobby over 1 year ago
    Hi VG20250603525 ,
    • Select the part, right-click, and choose Edit Properties.
    • Add a new property named HEIGHT and enter the desired value (e.g., 2.5mm).
    2. Go to Tools > Create Netlist > Setup.
    3. Under Configuration File, click Edit to modify Allegro.cfg file
    4. Under the [ComponentDefinitionProps] section of the cfg file, add the following line:
    HEIGHT=YES
    5. Save the .cfg file and generate the netlist.
    This ensures that the HEIGHT property from the schematic is included in the netlist and transferred to Allegro PCB Editor.
    Hope it helps.
    • Vote Up +2 Vote Down
